Yes I know no coil in a primatic or direct !! I have a primatic to fit this will be powered by a back boiler but it has 1 hole to many all i want is a diagram or something to fit it in !! simples ....Ste .
So why confuse the issue by pointing out that there is no coil in the NEW primatic!? And, comments like the above won't endear ypourself to contributors ESPECIALLY as the link I provided takes you to a pretty clear diagram!!
Sorry never looked at the link yes that is the same as what i have in the picture/diagram but on the left hand side their is only one hole the cold feed on mine their is one above 1" bsp I will try and post a photo ..
Oh thank you for all your replies
Ste
Ste .
Its difficult to guess at why you are involved in doing this.
I get this feeling that you are a DIYer who does a few jobs for people on a paid basis without sufficient knowledge and almost certainly without insurance.
If thats the case then thats why many feel that the plumbing industry should be better regulated so that only those with a proven basic knowledge are allowed to do work commercially.
And these are the male 1" fittings from the otherside of the tank which you cannot see into the tank or poke your finger through .... think these are to be connected to the boiler ? I need to know what side .... No I am not charging for this its a pensioner and as I have changed 10 hot water tanks in my life indirect/direct never come across one of these !!!
So as I am getting miffed I will connect up as a direct tank leave the boiler and just put the imersion on a timmer and stuff it .... cant afford a plummber so I took it on and a good deed
Ahhh so the 2 male connectors the other side (the one's closest together) are to be connected to the boiler ? and the top one the other side is to be blanked off and the bottom is the cold feed
ste ....
Seriously, are you SURE you have a Primatic to fit? They are seriously expensive, and the photos look like an indirect cylinder, but to be fair you should know what you are seeing inside. The tappings seem a little to far spaced.
