Priming a screeded floor.
19 Nov 2013
Essex
I need to prime a screeded floor ready to put the undertile insulation down, any recommended products for this?
I am using a 150w heating matt, by living heat. It's a 20m2 matt. I am laying on 6mm insulation board(it's blue) think it's called Xps/styrofoam.
Living heat said the screed needs to be primed with a "suitable primer"
I can't use 10mm insulation as it will be too high where it meets bifold doors and hallway.
Any tips/ advise would be greatly appreciated.
Andy
What type of screed is it? Sand and Cement or Anhydrite/Calcium Sulphate
Did the company who supplied the heating mat not supply the primer?
I used another company who sold as a package, I was able to use 10mm insulated backer board instead of 6mm as I have the height.
Have they told you that you need to prime the insulation boards once they are fitted too.
I appreciate you can tile directly on top of the Matt but that seems like a pain to do so I've used a self levelling compound on top of the Matt to make tiling easier.
No help to you I know :)
