I’ve done it a few times & It's a perfectly feasible way of plastering a very large or high wall in, say, a conservatory or even a very large ceiling which under normal circumstances, you would not be able to tackle working on your own & mixing yourself.Yes, i have used this method on a large ceiling before. Tack the stop end bead, which is like an angle bead with only one side, to the wall and plaster up to it. Then pva where your new plaster will meet the old and continue. This method is not as good as laying the whole wall on in one because it may need a bit of attention from the decorator at the join, but if you are on your own and the area is too large the result will be better than running out of time and leaving trowel marks everywhere.
I think the bit Bogan has (hopefully
