Hi, new here as I've just retired and started my own DIY.
My problem is not so much the shower but fitting the bloody thing.
Where it fits is a single tile without anything behind it. I mean no plaster or concrete board just a 7mm thick tile. So basically the raw plug just spins as you try to insert screw. Everything was followed as per instructions i.e. 8mm drill etc but not banking on having no purchase for plug. Any ideas how to overcome the problem?
So far I have tried larger screw, bigger plug etc. Can't use the plaster board type contracting sort as the thickness of the tile is so narrow it doesn't close up to 7mm. Only one I can think of is the spring type plug, but means I will have to drill the 8mm hole out to 14mm and it's very close to the pipe hole, so chance cracking the tile... Helppp
