The nearside front coil spring snapped on my 2004 Citroen Berlingo van, 2.0 HDI, 75,000 miles. Fortunately it happened when it was stationary and the spring ended up sitting on the top of the tyre, so didn't cause any further damage. I watched a series of youtube videos on how to replace a coil spring, and thought it looked relatively straightforward. The stage I'm at is trying to remove the lower strut mounting bolt, but it's not going as easily as it did for the guy in this video.
It was seized solid, so I ground the nut at the front of the strut off with my angle-grinder. I can get a reasonably good strike on the bolt with a hammer and punch, but I can't get it to budge. Unlike on the car in the video, the other end of the bolt is wedged against a protruding bit of the strut, which prevents it from rotating..
Does anyone know how I might go about removing the bolt? Any advice would be much appreciated.
