problem with 1deal he24 (1sar)
30 Dec 2007
i have a problem with the above boiler it is 2 years old the guarantee was up in may the central heating works fine. but the other day when i turned the hot water tap on it was only look warm. so when i looked at the boiler the pressure gage was on zero so i bled the system to get the pressure back up.when i turn the hot water tap on with the water running slow it got quite hot for a few min then it went back to warm. when you look on the boiler screen is a letter (d) which has allways been thier.when you first turn the boiler on it counts up to number 4 then the letter (d) comes on the is also a little box on the wall with 3 lights on it when i press the button a green light comes on and the boilewr gets a letter (c) on it and the burner light comes on with the boiler workig. but the hot water is still warm any one got any suggestions.thanks
yes the 22 mill pipe gets red hot you can not touch it.but after a short time the burner switches off.
what is a diaverta and what does it do.do you think i have put to much water pressure in when it went down to zero and i adjusted the pressure.
