Problem with Baxi solo 24
26 Jan 2011
Hertfordshire
We had a 'baxi solo 24' boiler installed 3 yrs ago along with a number of new rads etc etc to a grand cost of £4k.
The boiler worked perfectly for just over 1 yr and we've had the same problem that 4 seperate plumbing companies are unable to identify & fix.
Basically it goes to "lockout" and refuses to fire up, we have to press the reset button anything between 5 -15 times before it fires up.
If we go out and its left on timer it will never kick in and we come home to a cold house, unless we leave it on 24/7
Im at my wits end with it now as its getting worse and worse and taking longer and longer to reset. A friend of hubby's suggested with get BAXI out to fix it, is that something you recommend? :?
Yes!
Might be electrodes/door seals or pcb or something else depending on what 'lockout' code it is but heateam carry em all on the van......and the repair is guaranteed
