I recently swapped out my faulty boiler with a worcester bosch 24ri my wife's brother who is a plumber but has experience of replacing boilers. We also changed the room thermostat. It has a 3 way honeywell motorised valve. Controller is a Drayton 7. All works fine apart from the following that i have found through testing trial and error. This is with both hot water and heating set to 'on' on the Programmer. Hot water will not pass through to the radiators UNLESS the Hot Water Cyclinder Thermostat signals that it also needs hot water. If the Cyclinder thermostat is at tempreture then water will not pass through to Radiators even though the room thermostat is clicking to say that the room is colder than its setting. As soon as i run a bath with that condition, and then the Hot water cylinder thermostat then kicks in as cold water enters the cyclinder, then water also passes through to the radiators as well. I think it is either a fault part or a wiring problem. Please help!
