Hi I have changed 2 transformers that feed 5 downlighters each on the same circuit.
The first 5 work fine, but the second 5 are fine when turned on but then after about 30 mins start to go dull and gently flicker. After about 5 minutes of this they go back working fine for about another 30 minutes or so.
If i disconnect the transformer and reconnect when the dull flicking is occurring the lights work fine again but then start to flicker again after a short period.
I have changed the transformer but still no luck.
Wondered if anyone knows what could be causing this problem?
