Hello all, first post on here but get the feeling it won't be the last!
As the subject says, I've got downlight problems that seem to be getting worse the more I read about it.
First off, the bathroom downlights run in a bank of three. When I moved into the property two out of three were working, another one then went and wouldn't work when tried to replace it. Then the centre one stopped working! After looking at the connectors on the bulbs (mr16's) the central one is black (scorched?) as if it has too much power running through it.
I decided to replace the downlights. Didn't realise until taking the old downlights out that there is also a transformer in there (240v 12w going off memory). Purchased a set of GU10 downlights and wired them up but they didn't work. Wired the old downlights up again and the central one now works again! So now I'm not sure whether I purchased the wrong set of downlights as I didn't know about the transformer or whether the transformer is on the blink. The downlights all have 50w bulbs in by the way.
Add to it all I've read that the transformer should be kept away from loft insulation and realised when I found it the transformer was covered by insulation! So not only have I got lights that don't work I also have a fire hazard! Not good!
Any help greatly appreciated!
