Problem with Ideal Classic Boiler Dropping and Reigniting Flame - Video Included
3 Dec 2015
Noticed what appears to be weird behaviour from our (Ideal Classic) boiler, it often seems to be dropping and reigniting the flame over and over
any ideas?
obviously I would not touch anything related to the gas side of things so if its that side then just some idea so I can judge possible costs :)
http://tinypic.com/player.php?v=a3cjnd&s=9
Yes, it will be a gas/combustion issue which we cannot advise on here.
Usually fairly simple cause and often a symptom of a lack of servicing. But could be the PCB.
Presumably you have a gas cooker which has a stable flame when the boiler is running?
So likely to be about £84 to £184.
Tony
Thank you so much, that makes sense as it hasn't ever been serviced (15yrs) I will get someone booked in, it's good to have an idea so that you can be a little knowledgeable when the repair folks come
Its also good to get it serviced occasionally.
Just shows how reliable that model is even when never serviced!
Tony
