problem with kitchen corner unit
20 Jun 2013
Hampshire
I have fitted a magic corner unit to an 800 x 800 unit it pulls out on the right hand side. I am now stuck with what doors to use. The gap on either side is 38mm x 71.5mm and there is no corner post. Ideally I need both doors hinged together so that I can put a 280° hinge on the right side so that it doesn't restrict the baskets on the magic corner mech. Hoping someone has a solution. I have only just got into DIY as my husband is ill and can no longer do it. Thanks
I think we definitely need some pictures. Did the unit have doors before you fitted the 'magic' unit and if so why can't you use them again?
