Hi
I had an isolated lockout a couple of weeks ago.
Heatteam came but found no problem.
Since their visit something strange has been happening.
Sometimes the heating doesn't work properly - the orange light is on continuously (just means boiler on & receiving mains supply as far as I can tell). No red flashing lockout signal.
If I turn on call for heat (e.g. wack thermostat up to 26 degrees) nothing happens - no flashing to indicate boiler registering call for heat.
I did see it flash green a couple of times, which means boiler temp satisfied - but it shouldn't be as the demand for heat was present (the thermostat clicks on at about 19 degrees).
I did get it working again by turning the boiler power supply off & on again at the wall.
However when I tried that last night the fuse blew in the mains power switch & I had to change it !
Very strange.
Could this be the PCB ?
I've booked another visit.
PS There are 2 separate thermostat-like knobs near the boiler as well - one directly above set at "20", the other away towards the header / hot water feed tanks set at "3". Any ideas what these are ?
Very strange.
