My lounge was fitted with high-quality engineered wood flooring. The floor was laid on an acoustic underlay and each board is firmly locked side, back and front to adjacent boards by tongue and grooves.
After less than a year, one of the boards developed a bulge at its edge, which became raised slightly above the adjacent boord. The fitter’s solution was to cut out the board with the bulge, remove the underlay from underneath it and then lay a new board in the same position after cutting off its tongue and grooving.
However, there is now a loud, and I do mean ‘loud’, squeaking whenever walking on or near the new board and there is visible movement between the new and adjacent boards.
The fitters solution is now to remove the new board, and then prize up the adjacent boards slightly and squirt or brush glue underneath them as far as possible. He then plans to glue the new boord directly to the floor.
My concern is that, although the new board might be bonded firmly to the floor, he will be glueing only the edges of good boards to the underlay and they will still be able to move up and down slightly as the underlay compresses under load.
I can’t see how the integrity and strength of the floor can be maintained by his solution and I feel that the proper method is to remove all the boards from that section of the floor and re-lay them all so that they are all locked to each other by tongue and grooves. Am I being unreasonable?
