i am going to install an aga multi burning stove in my home, i have taken my old fireplace out and exposed the opening as much as i can and replaced the existing fire surround that is made out of cast iron, the flue is a clay liner which measures 11 inches external diameter and 8.5 inches internal diameter, because the clay flue liner is tight as the back of the chimney i have decided i am going to drop a stove flue liner down which will allow me to off set the pipe slightly as from my flue plate to the clay liner i have 12 inches to play with, do you think this will be ok? i am wanting 100mm clearance at the sides and the back of the unit.
Now.
the main problem i have got is the sides of my opening are brick and the back of my opening is breeze block, i want to bring the sides in a few inches and then tile so that the tile finishes flush with my existing cast iron fire surround, so as you look into the opening the tiles are flush, render wouldnt work very well for me as i need to bring the sides in 2 to 3 inches
i did think about plasterboard, light skim of plaster and some thick tiles with cement based grout but some people say this is not good enough.
I also thought about a cement board and using dot and dab to secure it in place and then tiling straight onto it..
im guessing to be fair on this one and am struggling, i need some advice before i do any more work. hope you might be able to help
Now.
