Sorry about the long post but I hope some experienced plumbers will be able to help me out with identifying the problem please
Lauren
Our Bristan shower (which is over the bath) combined with a varispeed 50 water pump has started to play up.
What happens is when we run a bath (for example bathing the kids) then about 5-10 mins later when we try to use the shower to wash their hair the shower does not seem to draw any cold (which makes the shower dangerously hot) or sometimes hot water into the flow, which is causing the pump to make a loud noise as it tries to pull the water through?
Could it be air in the system, as sometimes when running the cold bath tap to get rid of the problem with the shower the water splutters out before going full flow? However yesterday when running the hot bath tap there was hardly any water coming out?
After turning the shower on and off, running the bath taps etc seems to get rid of the problem, but I would like to know the cause and the recommended fix please
I have checked the cold water tank in the loft which is 114 litres and it is filling up fine when water is being drawn through the shower so I am at a loss to work out why this happens sometimes and other occassions its fine
Not sure if this is relevant bu my boiler is a Worcester Bosch Greenstar 30CDi system boiler http://www.worcester-bosch.co.uk/homeowner/products/gas-boilers/greenstar-30cdi-system http://www.worcester-bosch.co.uk/homeowner/products/what-is-a-system-boiler with just a cold water tank in the loft
Lauren
