Problems with Underfloor Heating
30 Sep 2007
Midlothian
Hi there
Can any one help me with this? I have just moved into a new house, where I had Thermolay underfloor heating installed in both the main bathroom and the en-suite.
The control panel is the TPT44. This panel seems to react to the current floor temp probe and adjust its output accordingly ('floor limiter' I believe), although the instruction manual does not mention this specific function as a feature.
I have managed to get the main bathroom system working fine, however the en-suite system seems dodgy. When checking the panel for the current floor temp, it always reads as very high (reflecting the 'floor limiter') and does not remotely reflect the actual temp. I have tried various settings but each time, the alleged current temp reading rises to the maximum dictated by the floor limiter. CLearly, this causes the heat supply to cut off and my floor is no where near the temp intended.
Can anyone shed some light on why this could be happening and how I can go about sorting it? I have visions of having to lift my tiled floor to sort this one and that does not appeal.
Any advice would be welcome.
Thank you.
if you have two controllers can you swap them over if all ok on the faulty floor you will know its the controller if its the same it could point to the cabling
Thank you Fireman.
I'll need to find someone to help out with that suggestion as the bloke who fitted the system placed the control panel about 4 inches off the ground (despite instructions stating panel should be at eye level) and at 8 months preggers I might get onto the floor to have a go but I doubt I'd manage to get up again!!!
I'm so hoping it turns out to be a calibration error rather than anything major.
Thank you once again for your reply.
