Hi folks,
I've actually posted in plumbing already, so don't go saying I'd be better speaking to a heating engineer...! I reckon you might be able to help here... I have some elec experience but not sure how on earth a basic heating system is wired? (ie: the idea of a live feed to turn something off??)
Here goes- the programmer for our heating went yesterday and I replaced it today (new Danfoss FP715Si programmer)
You know how the backplate has L, N and 4 switches, on & off for each CH and HW. (non combi system, separate control of heating & HW, fully pumped)
Point is, the old terminal block had the L linked to the off for both CH and HW. As per instructions for new programmer (which seemed confusing on the matter) I removed this link but wasn't sure whether I should have? Now the programmer works for turning on HW and CH but if I try to switch both on at once then the programmer dies and the boiler goes off. an error code flashes and then it turns off. I need to turn off the power and restart it.
Do you reckon I should reconnect the live to the 'off' switch terminals again?
See I don't get how you need Live going to anything when it's switched off. I understand the turning it on bit... Can anyone enlighten me with the general idea even, which might help...
Thanks!
Thanks!
