Prog Room Stat Help
29 Jan 2009
Essex
Just purchased a danfoss TP7000RF programable room stat and transmitter RX1 to fit to my FER Falcon II boiler. I am a little concerned that I have to wire the transmitter to the mains, as my boiler states a 24v stat should be used......question I have is will there be a 240v charge put across from the live feed of the transmitter to the low voltage switch circuit of the boiler which the transmitter will control via the room stat?
Thanks in advance, Ian.
Thanks for the quick reply. Just was not 100% if there was any cross over voltage. Thanks for confirming
