I am going to change my ordinary mechanical stat for for one of these. I have acquired a Sunvic TLX6501 although it is relatively crude and doesn't have as much functionality as I would have liked (the instructions for the TLX6501 on Sunvic's website are for a more sophisticated model but with the same name). The Sunvic has optimum start on the first 'comfort' switch-on of the day.
However, the Honeywell CM67 seems the be the 'daddy' of programmable thermostats with enough set-points and features such as holiday, party and day off buttons, although they seem to be in the £50 to £60 range. It seems well recommended on here.
Does anyone know whether the CM67 optimum start operates on all higher temperature periods or just the first one of the day?
How does the CM67 determine when to start the heating? Does it start a fixed amount of time earlier dependent on the difference between current and required temperature or would it learn how long my system takes to heat up? I can't see anything in the installer guide on Honeywell's website.
After doing a forum search, I found someone said that they disable the optimum start feature on a lot of their installations as a lot of people find is disconcerting or they are sitting in the cold while the stat thinks no heat is needed (I can't find the post now). I can't see a reason for this. If people are cold then surely the time settings are wrong? The primary reason for a programmable stat in my opinion is comfort, with little to be made in efficiency savings (or the reverse). Surely the room stat should, on most days, just provide a set and forget operation where you let it do the job and the house is warm when you have set it to be.
Then again, I'm sure many people in general don't understand the principle of a thermostat, turning it up and down unneccesarily. I moved the limit pegs when in a houseshare, to stop a housemate upping it to 25 degrees because he was cold. The reason for it being cold was that the house would only about 18 and still warming up!
Thanks,
James
Thanks,
James
