Thought I'd share my Unvented install (not sure why or if anyone's interested, but here goes)
had set up the inlet, balanced cold and hot and just setting up the flow and return with balance valve.
Found the flow feed fowled the immersion so dropped it down a couple of inches...also fitted here is the expansion vessel, balanced cold feed take off for the shower (to the right of tank in the picture) and hot feed for shower at the bottom of the picture...
close up of the pipework and inlet group...
probably not the most exciting pics, but want to keep some pictures of the 'during' of the build....
yes, I'll be turning the flow and hot water outlet valves round so they point in the direction of flow...i think little details like that make a bit of a difference.
here's the pipes for the his and hers sinks next to the shower, and 28 mm cold water inlet...that comes off a 32mm MDPE i replaced as one of the first jobs in the house to get rid of the lead pipe!
floor will be fully inserted when done...just easier to work with no dead teddy bears in there at the moment...
If anyone can spot anything obviously wrong, do point it out now, won't you
Cheers,
Virgil
Cheers,
Virgil
