I examined a failed prv some time ago. I found by twisting the cap anticlockwise about quarter turn the cap raised about 3mm.
Beneath the cap there was no hexagon, but there was a slot.
I then made a ' C ' spanner and slackened and removed the head.
The head held a rubber washer which is held against a brass seating face.
In hindsight I realize I could have dismantled it in situ and cleaned it up.
But would it be as good as new? don't know but worth a try
I did find sediment that had got trapped between rubber washer and seating face
