Is PTFE tape needed for compression fittings? Some plumbers seem to be recommending using them mandatory basis, but some don't recommend and never use PTFE at all in their own works.
What is the truth? I have been using PTFE wrapping over the olives in compression fittings 3-4 turns around it, and the result is 90% dry and perfection connection.
But there is one or two cases where PTFE wrapped compression fitting was showing either wet patches on the nut and pipe connection seam, or shows a very tiny drop (about 1mm in diameter) pushed out from the seam every so often, which had to be wiped off with tissues. When this happens, it needs to be taking it out, and connecting again, which can be hassle.
