Hi DIYnot'ers,
Please could you assist me with a stinky situation that has lead to the underfloor of my house being flooded with sewage?
Around Sept 2017, the street that I share with 4 other properties became flooded with sewage twice in a short period of time. The sewage was escaping from an inspection point (IP1 on diagram) towards the read of my house. The source of the leak was slightly elevated relative to the floor of my house. The water/drains company attendend, and on each occasion they cleared an obstuction about 7m from the inspeciton point.
Now, approx 3m later, there has been a similar incident, but the results were a little more unpleasant. A few days ago we noticed that the drains weren't clearning very well. There hadnt been any issues on the road like last time, so assumed it was a local problem and applied drain cleaner over night. In the morning, noticed that things hadn't improved, but left it for the time being. Later that day, I heard what sounded like a large rush of water, followed by the toilets gurgline and with their water levels sitting low. Within a few minutes there was a terrible smell. I manged to figure out that the smell was coming from underneath the house so opened up the floor with the intention of going down to take a look. Unfortunately, the entire sub floor had become flooded with stinky water to a depth of about 1.5 inches.
Still assuming it was an internal issue, I called a company out to inspect. The first thing they checked was the inspection point that had previously overflowed, and found that it had again become blocked, though this time instead of overflowing into the road, it had managed to find a way into my uderfloor.
They put me on to the water company, and they came out for a third time to unblock the street drain. Again there was a blockage around the 7m point. After unblocking, they hoovered out the internal flooding as best they could and performed a CCTV inspection.
What they found was:
- The drains were now pretty clean
- At the 7 meter mark, there was another manhole and what looked to be my property joining the drain from the left hand side.
- Just past the manhole there is what looked like a sealed join from above.
They weren't able to locate the manhole in the street. It could be that it is burried under the road. Alternatively, it could be that is located under the property. I'm going to get a metal detector and try to resolve is location
I've drawn a diagram of the layout as best I can. It's not clear to me whether the drains actually run in a straight line from IP1 to the main sewer manhole cover in the road (Marked by line A), or whether the drain runs from IP1 along the road next to my house (Marked by line B). Both of these possibilities seem odd though as (A) would run a shared public sewer under my house, and (B) would have it joining the main sewer away from the manhole in the road.
A few final bullet point facts...
Drain shared with 4 other proprties.
If the missing manhole is under the house, that part of the house was build in the 1980's.
There are two inspection points roughly directly opposite the 7m mark on the other side of the house (IP2 and IP3) on a neighbours land. It could be that these are running under my property into the 7m manhold spot, but I'm not sure at the.
My house joins drain after the inspection point
My working assumption is that I have something under my house such as a sealed manhole that is connected to the drains that were backing up. In the past it stayed shut, and the water backed up into the street, but this time it broke, and all the backed up water has escaped into my property. If this is the case, it's quite likely I'll have future issues whenever the public drain blocks.
I'm still trying to get my head around what has gone on. I'm waiting for the underfloor to dry out and probably go down there in a few days to investigate, but I'd really appreciate it if anybody could help on the on the following. x:
Any thoughts / suggestions on how so much water could have got from the sewer into the subfloor. It did not escape from up the toilet/bath/sinks. The onset of the smell was accomanied with quite a bit of rushing water and gurgling, so I'm assuming something just gave up, but I'm not sure what.
If it turns out it was from a manhole underneath my property, who would be responsible? I can understand issues with private drains being my own problem. But if the manhole was servicing either the neighbour with the 2 instpections points, and / or the 4 other houses on my street, would that make it a public drain and the responsibity ot the water company?
When researching, I came across the term, 'build over agreement'. I'm not sure I have / should have one? I purchasd proerty about 18m ago, and as far as I know, the problem area of the propert was buildin the 1980's
Is this something that I can / should be getting either my insurance company or the water company to resolve? I've tried reading up on this, but between possible 'defective work' and 'private asset' clauses, it's pretty confussing.
On the assumption that this is going to happen again, what could I do to prevent it? I've seen there are products such as a non return valve that could be fitted to a manhole, but presumably I'd need to find the manhole first
Are there alternaives, and what type of tradesmand would I need for this? Is it a plumber or somebody more specialised?
Appologies if some of these are stupid questions, and many thanks for any advice given.
