Agreed. Except it's not a pudlock - it's a putlog. They used to be, literally, a length of log built into the work as it proceeds. You sometimes can still see the holes up the sides of ancient stone buildings and very often see them on modern buildings where the joint has not been filled in after the putlog is removed.
I always thought they were called putlogs too jeds (thought the OP had made a typo) but then I'm no scaffolder. The last time I erected some myself it was of the "Yellow Jelly" variety
The company that I started work with early 50s still used birch poles as standards and ledgers spliced together with wire bonds with 75x75mm beech board bearers.
The bearers were called putlocks and the holes for the bearers were called putlogs.
When present day tube scaffold came in as we know it now, the putlock name was dropped and they were called putlogs.
old un.
I think you may be right oldun. Although lock and log have probably become interchangable these days. One thing it ain't though is 'pud'. Pud is strictly reserved for pudding. My favourite being bread and butter pudding.
