I was - but I don't really understand your views .
I do my best to explain.
Why then, is it different than using any other word wrongly?
Again, I think you do really understand.
Let me try a slightly different way of putting it ...
In the case of 'use of language', with an 'unregulated' language like English there is
not really any 'right' or 'wrong' - all we have is 'common usage'. English dictionaries document current common usage but do not 'define' it, and certainly don't introduce changes/'requirements' in terms of how the language is used. I think that most languages are like that (some may be poorly, if at all, 'documented') but I believe that there are at least some (like French) for which the use of the language is 'regulated' and 'defined' by some official body - hence, in those cases, at any point in time there
are 'rights and wrongs' (just as with anything else subject to regulation). One should be able to distinguish the two by 'chronology', since the changes in an English dictionary inevitably follow ('lag behind') changes in 'common usage' (and canm never precede such changes), whereas in a regulated language, changes in 'regulations' will usually precede changes in common usage to comply with those changes.
Things like units are highly regulated/defined, by national and international bodies - so in any country (often many/most/all countries) at any one point in time there will be (and must be) explicitly defined 'rights and wrongs'. You surely must agree that it would be crazy (and totally 'wrong') if individuals started using words like pint, litre, gill, pound, kilogram, metre, mile, volt, Ohm etc. etc. etc. to mean something 'wrong' (differing from the universally-accepted definition, hence essentially universally-used) and that such an error ('incorrectness') would simply not be allowed to spread to the point that it eventually became common usage?
Well, it sort of has and is. It means a tenth - decimetre etc.. ... Probably the ignorant used the word wrongly then more copied them ...
It presumably must have been something like that (as I wrote, seemingly best part of 400 years ago) - but I still find it hard to understand how such a degree of 'incorrectness' managed to 'catch on' to such a degree. It's a bit like having a situation in which increasing numbers of people came to use the word 'cold' to refer to something with a high temperature, to the eventually extent that it became accepted 'common usage'.
- the same as happens now when people spell and pronounce 'have' as 'of' or you using 'less' when it should be 'fewer'.
The former is an (I would say 'understandable') 'phonetic' thing. Particularly when "have" is abbreviated (to " 've' "), and given variations in voices/accents, verbalised versions of, say, "would've" and "would of" can be so difficult to distinguish that I'm not surprised that some have also come to write it incorrectly. As for the latter, and as you know, I am as much a culprit as anyone else (I have a habit of using those 'interchangeably'!) - but I agree that both those issues may have been avoided had people (including myself) been repeatedly 'corrected' at a fairly early stage in life.
Only inevitable if not corrected.
As above, in terms of the English language there is not really any formal 'right' or 'wrong', so really nothing to 'correct' - the mostonec could really do would be to point out that something differed from current common usage.
I have answered several times saying if that were the case then that would be the norm and we would know no different - sort of obvious really.
That's not really an answer to my question. We know that such is not 'what happened' but I'm trying to get you to tell me whether you think that people should have been repeatedly 'corrected' whenever they used English in a manner which differed from what Chaucer (or whoever) would have used it, such that it would have happened, and we would all be speaking and writing "Chaucer's English" today.
