this is one of those comments I frequently hear and each time wonder what it really means.to be four times close to
[ Firstly, apologies for two 'typos' - firstly the missing "r" in what should have been "closer" and, secondly (and goodness knows why I did this!) it should be "six times", rather than "four times"! ]this is one of those comments I frequently hear and each time wonder what it really meansto be four times close to
.Assuming you're talking about my comment regarding separation of gas pipes and electrical things, I actually it meant that 300 mm is "4 times" 75 mm
(here)I don't know what thread it was pulled from ...
When used in the correct manner, there's nothing wrong, conceptually, with percentages greater than 100%. To say, for example, that the cost of gas is " 250% " of the cost of electricity is obviously no different from saying that gas costs 2.5 times more than electricity.... but I can see the problems with 150%, the first time I came across it, was running and engine on two fuels to calibrate the engine, and we then ran it with a fuel under test to see when knocking started, and quoted the percentage of Octane it was equivalent to, and if the screw went past the 100% calibration point we could get over 100%.
I don't get hung up on errors/typos unless it obviously changes the meaning or done by a know nothing idiot. Neither apply here[ Firstly, apologies for two 'typos' - firstly the missing "r" in what should have been "closer" and, secondly (and goodness knows why I did this!) it should be "six times", rather than "four times"! ]
Yes very much so. Six times further than 25mm is very concise and irrefutable, whereas six times closer than 150mm is fundamentally indefinable.As I imagine you probably understood in this case, had I typed this correctly, what it would have "really meant" was that 150mm is "six times" 25mm - i.e. that switches & sockets were allowed 6 times closer to gas pipes than other electrical things. Would you perhaps regard it as clearer had I written that the separation for switches etc. was allowed to be "one sixth" of that for other things?
I'll start by saying this is not a pop at you and generally I'll accept such comments as a very cack handed way of describing a fractional reduction of something if it makes sense.Having said that, there are certainly situations in which statements about ratios, proportions and percentage differences/changes are worded in a way which can be ambiguous, due to uncertainty about the denominator which has been used. This is probably at its worst with 'percentage reductions', and at its very worst with things like "100% reduction". I think that nearly always actually means (is intended to mean) an actual 50% reduction (rather than a true '100%' reduction 'to zero') but at least it is usually obvious from context that it is not intended to mean a reduction to zero.
The worry (and perhaps uncertainty) then is that if someone might (incorrectly) say "100% reduction" for a reduction from, say, 10 to 5, one has to wonder how they would describe, say, a reduction from 10 to 8 - would they (correctly) call it a '20% reduction' or (incorrectly) as a '25% reduction'?
, differences
Although I suppose I can understand your uncertainty, I don't personally find it hard understanding that sort of form of words. The real
Absolutely and I recall 2 of our teachers at school having opposing opinions on the topicWhen used in the correct manner, there's nothing wrong, conceptually, with percentages greater than 100%. To say, for example, that the cost of gas is " 250% " of the cost of electricity is obviously no different from saying that gas costs 2.5 times more than electricity.
And that was the stumbling block between the 2 teachers.However, in many contexts (when one is talking about proportions/percentages 'of a whole'), percentages greater than 100% are obviously impossible, hence meaningless. If one is talking about, say, the percentage of the weight of a human body which is accounted for by fat (or water, or whatever), it obviously cannot be more than 100%.
Yes. Some are unable to understand that distinction and knowing a reduction of 50% also means to 50% will expect that to apply for any other figure IE: a reduction of 10% also means to 10% rather than the correct figure of 90%. They would expect a "25% reduction sale" to mean final prices of 1/4 of original rather than 3/4, but I've also known it to mean 25% of stock reduced in price (possibly with small print price reduction of something different to 25% and maybe variable across products) and when the tills established the stock level had been reached the discount stopped being applied.One of the most common potential problems arises in relation to percentage changes/differences if people use the wrong wording. To say that the price of gas has "increased TO 150% over the past X years" is obviously very different from "increased BY 150% over the past X years" - since the former means that an initial price of, say, 20 p/kWh will have increased to 30 p/kWh, whereas the latter would mean that it had increased to 50 p/kWh.
This is quite an interesting discussion for me since, over the years/decades, a fair bit of my work has related, directly or indirectly to the abuse/misuse of statistics (in the broadest sense), be it deliberate or 'accidental' (through ignorance) - and such abuses/misuses very often involve 'percentages'. The perpetrators are most often 'the media', politicians, business leaders etc. or 'pressure groups', but also sometimes people/organisations who/which really ought to know much better!Yes very much so. Six times further than 25mm is very concise and irrefutable, whereas six times closer than 150mm is fundamentally indefinable.
Oh dear! That is definitely a case of 'mathematical ignorance'.... if another hadn't joined in and started explaining a 30% price reduction followed by a 30% rise took it back to the original price ...
Sure, but that's just incorrect maths, and is nothing to do with expression of the changes as percentages. A 'halving' followed by a further 'halving' takes one down to a quarter (of the original figure), not zero10% reduction of £100 = £90 and a further 10% = £81 not £80 seen this done a lot.
One of those teachers presumably didn't understand the difference between situations in which "100%" represented an absolute upper bound, which could not be exceeded (usually because it represented 'the whole' of something, and one can't have more than 'the whole!) and other situations in which "100%" merely represents a present/past figure which may well be exceededAnd that was the stumbling block between the 2 teachers.
You're talking there of situations in which, deliberately or otherwise, language is being used which simply isn't clear enough, to anyone. In contrast, a mathematician or otherwise reasonably numerate person would see nothing ambiguous about, say, "a 25% reduction", since they would assume that that language was being used correctly.They would expect a "25% reduction sale" to mean final prices of 1/4 of original rather than 3/4, but I've also known it to mean 25% of stock reduced in price (possibly with small print price reduction of something different to 25% and maybe variable across products)...
I've also known a man try to take a building society to task over interest payments on a fixed rate mortgage. His standing order was set up to be paid 3 monthly despite the agreement being monthly, accordingly the annual statement showed the interest amount applied each month (presunably based on daily calculations) rising then the monthly repayment increased to cover it.10% reduction of £100 = £90 and a further 10% = £81 not £80 seen this done a lot.
Why did he set up a 3-monthly Standing Order if the agreement was to pay monthly? Unlike the situation with Direct Debits, with Standing Orders one can dictate exactly how much will be paid, and when (how often).I've also known a man try to take a building society to task over interest payments on a fixed rate mortgage. His standing order was set up to be paid 3 monthly despite the agreement being monthly, accordingly the annual statement showed the interest amount applied each month (presunably based on daily calculations) rising then the monthly repayment increased to cover it.
