I live in a bungalow and have just fitted a new bathroom suite and have got pulsing problems with my shower pump.
I re-arranged the plumbing as it was old anyway.
The way I have done it now is that:
On the hot side:
Pipe from the cylinder all the way up to create the vent in tank above (2 metres above).
300mm above cylinder I have tee'd off and fed pipe to pump, next to cylinder which then drops under the floor and feeds my bath and shower.
300mm above the first tee I have tee'd off again and then dropped pipe under floor and then fed to basin (2 metre away) and also kitchen hot (gravity).
On the cold side:
From the tank, I have dropped pipe to pump, then dropped under floor to feed bath cold and shower cold
300mm above the pump I have tee’d off and then dropped pipe under floor and fed basin cold and toilet (gravity).
It’s only when I use the basin taps the pump pulses when either the hot or cold is turned off, I fitted non return valves about 1 a metre away from basin but it makes no difference.
I have noticed that when the taps are turned off they produce a meaty vibration through the pipes more so on the cold.
Since fitting the valves, the balancing of the basin taps are poor.
The basin tap is a Bristan mono type; anybody got any ideas as I’m lost now.
On the hot side:
On the cold side:
