Puma 80 constant noise
10 Aug 2006
Hi all, Puma 80 ,since I have come back from week away has developed a constant noise, hard to describe but a light droning noise,fumes are being expelled from the flue and a noise from the flue indicating boiler is on but not as loud as it would be at full power. The boiler is NOT being used when this happens,no hot water or ch being used. If I switch off the electrics the noise stops. Any thoughts?
If you have the pilot version the noise will be the fan running on low speed (to supply combustion air for the pilot). The fan may be wearing out hence the noise. A new fan would be a good idea.
Thanks for reply, I did wonder about fan - just smelling the fumes from flue threw me a bit with boiler not in commission.
These boilers are about 10 years old now and the fans are towards the end of their life.
Fan failure is a common fault, so much so that we keep them in stock!
Tried to get plumber (corgi) to come and do this job as I want boiler serviced too (plus pressure release valve & ch temp switch need replacing!) but cannot get anyone for over a week. Is it safe to use the boiler with the fan like this?
