pump head change on ideal isar combi
27 Feb 2010
Liverpool
could anyone please tell me if a 1550 grunfos pump head would replace the factory installed pump head on an ideal isar combi?
I think you should use the UPS 15/60 rather than the 15/50, more expensive but trhe 15/60 gives a 6 Metre head, which is probably the spec for the original, but be careful many modern combis have a unique pump that runs at low speed in heating mode, and high speed for HW mode, (such as Remeha for example) so you may need to get the correct spec ;)
Grundfos multi-head fits and it comes with a seal kit.
