if you have your pump in the return pipe, should the lock shield valve be on the return or flow side of the rad?
i understood that it doesnt matter whether its on the flow or return, but with the system being under negative pressure, i wondered does it make a difference, as a friend of mine says that if you have the LSV on the flow side it can affect the pressure adversly when its a pumped return
