pump keeps running
14 Oct 2008
Surrey
My Suprima boiler works OK, but when the boiler swiches off, the pump will continue to run until the boiler switches back on at the next timed cycle.
When I open the boiler door, a LED is flashing, I then press the reset button and hey presto the pump switches off..............what d'ya reckon?
Check that permanent Live and Switched Live are the correct way round, if they are probably PCB :wink:
The boiler used to work fine, it's just developed the fault over the past couple of months......................would this be a common fault with potterton suprima's
Put the PCB in the skip, the latest version of the board with new wiring loom is much more reliable :?
