Hi, i've got a problem with my suprima 40 which i hope someone can help me with.
1. Boiler will ignite either manually or via the timer on control unit.
2. Pump does not engage.
3. After a couple of minutes their is a loud banging and clanking noise that starts around pump area and travels down stairs into the boiler itself.
4. I have checked power supply at pump, no power present. i've gone back to boiler removed side panel and found there is no power from boiler up to pump.
5. Have found that although when tested no power out put could be found it obviously kicks in at some time because this problem has been occurring on and off all week.
Could it be a pcb fault?
