I have a BoilerMate II with a Potterton Suprima.
There are two Grundfos pumps attached to the BoilerMate II.
The pumps were recently changed after one of them died and we took the opportunity to have some chemical cleaner put in. The system was run for a while and then drained and topped up with inhibitor.
The system seems a bit noisy. It sounds like turbulence. Ive noticed that there are some switches on the pumps and I'm wondering if they're perhaps on the wrong setting. Could this be a cause?
I don't want to get a man out just to be told the pump's on the wrong setting.
Should I just change the setting the switch is on? What could be the consequences?
Cheers!
Cheers!
