I have a large house over three floors, the boiler is oil. Ever since we moved in about 8 of the 23 rads in the house don't get hot. I have bled and carefully balanced the entire system with no luck. I can make any single rad hot by turning off several of the others.
I got a plumber in who said we had too small a pump (Wilo Gold 60) and he replaced it with a Grundfos 15-60. Net result £300 out of pocket and even more rads cold. I have looked at the specs of the pumps and I reckon the Grundfos is less powerful than the one he took out but I am no expert. How do I decide what pump I should have or if the pump is the right size for the job?
The plumber also pointed out that the system seems to be made entirely of 15mm pipework which is too small for the size of house and number of rads..
I had the floor up myself at the weekend and it appears to me that there are multiple places for there to be air stuck. I have read that at the top of the drops to the downstairs rads I should have "air vent elbows", what are these and where can I get them in the UK and do I need them on the tops of both feed and return?
I am thinking of replacing a large amount of the 15mm with 22mm so that each 15mm run from the pump only serves three rads, is this the right thing to do?
Any suggestions clues or general advice most welcome.
