pump terminology
29 Oct 2009
hey guys,
i've been asked to check a pump for a dhws that tripped its overload relay today. Cant find anything wrong electrically so I suspect pump is getting on a bit. Its a BOSS pump with a twin head
Model: Type GLSD 40-50F
other numbers on it are
FLC(A) P1(W)
0.66 140=1
0.68 148=2
0.72 160=3
I cant seem to find much on net about it so Im after advice of what Im looking at here.
What do the 40-50 numbers mean?
The other numbers I thought may have something to do with speed settings but I don't recall seeing any speed adjustments?
If exchanging do i just try to match as best as possible?
cheers as usual and apology's if this maybe daft
It is actually a Grundfos Pump badged BOSS (for Wholesaler BSS)
UPSD 40-50 designates the size & duty head of the pump
FLC(Full Load current) indicates the motor current in Amps at the three speed settings
Speed adjustment is effected by moving a multi pin plug under the terminal box cover
You will need to find out if the pump is 230Vac 1 phase or 415 Vac 3 pahse
this will be on the data plate with all the other stuff you have recored
Speak to your nearest BSS branch , you may be able to get replacement heads for the pump which would be cheaper than replacing the whole thing :wink:
excellent thanks for that
so what does the size and duty mean? is this related to how much flows? so eg 40-50 litres/min or is that totally wrong LOL
have other bigger versions on site also and these have the speed adjustments but dont remember seeing them on this one. Will check again 2moro
its single phase 230V
40 = 40mm bore
50= pump head in KPa
F= Flanged
If its on DHWS it should be bronze or stainless
thanks spudkey thats info i wanted :) at least i know what it is now
i'll be honest here with a terrible answer....its blue :D LOL
thanks
