Push button flush issue
5 Aug 2004
I currently have an issue with the push button flush on my toilet cistern. If I press the left hand button the flush performs as normal with no issues. If I push the right hand button for a full flush then the flow of water into the toilet bowl doesn't cut off fully. I f I then open the lid of the cistern and gently push what I presume is the valve over the top of the water outlet to the toilet bowl it dropd down and the water then cuts off. Apologies if this is a common issue, I did check to see if had already been covered but couldn't find anything.
