Hi my push button button appears to have stopped working.....it seems the bit in the first picture has become detached. Anyone know where it goes or can offer any help please.
The two little arms sticking out of the end of the push button assembly in the first picture slot into the side of the cylinder in the second picture. The larger arm that moves when you push the button lifts the cylinder to start the flush.
This should give you the idea: https://www.amazon.co.uk/dp/B00VX68DIG
Usual problem is that one of the clips where the two little arms clip into on the cylinder has broken off. This will mean replacing the cylinder. A fairly straightforward job.
You'll have to buy the kit. Yes, the cylinder will replace yours.
Turn off the water supply and flush the loo (pull up the cylinder). Note the orientation of the cylinder, press slightly down, rotate anti-clockwise, lift out. Set up the new cylinder as per the old. Fit the new cylinder by rotating clockwise until it clicks/locks in place. Carefully attach the flush assembly.
Take the old flush unit out of the cistern as described above. Hold it against the unwrapped package to compare and see that you have the correct replacement.
