PUSH FIT FITTINGS BEHIND A STUD WALL?
17 Jan 2008
Newcastle upon Tyne
Hi all, thanks in advance for your replies. Im currently installing a down stairs bathroom and for ease of use im think of using push fit fittings. These will all be concealed after im done. Either behind the stud work or under the floor. Would this be a bad move as they will be unaccesable afterwards? Any opinions on this?
Im also moving 2 RADS which are currently plastic push fit fittings, should these be changed?
Thanks in advance. :lol:
I would not use push type as they have been known to fail. Yes its a bit more work to use say solder ring but you will sleep better at night. Different story if you can easily get to it.
