Push fit fittings
1 Mar 2005
Stirlingshire
Hi, Can I incorporate plastic push fit fittings with copper pipe or are these only to be used with plastic pipe.
inserts with copper kevplum? :lol: leg iron will be giving you stick for that one.
op, make sure that the copper is deburred and square in all the joints. If it's pizzed it can leak.
check hepworths site :idea:
hep20 has inserts for copper
and as for leg iron he can
That's for when you're fitting a plastic pipe into a copper compression fitting, the op wants to fit copper pipe into pushfit fittings. :wink:
