Plastic Pipe Fittings
14 Jan 2005
Glamorgan
Is it OK to fit a 15mm copper pipe into a plastic T piece when the other 2 fittings are both 15mm plastic pipe? To clarify, this is the push fit/lock type plastic fittings.
Cheers all.
Yes, just make sure :-
The pipe is round and clean
Preferably cut with pipe cutters, if you use a hacksaw make sure you remove any sharp burrs that could “nick” the O ring
Insert pipe fully into fitting
