    Dismiss Notice
Pushfit and platic pipe with a shower pump?
Discussion in 'Plumbing and Central Heating' started by Finnis, 10 Mar 2006.
  1. Finnis
    Finnis
    22 Dec 2003
    20
    Thanks Received:
    Country:
    Hello all,
    I have a shower pump fitted in the airing cupboard in our main bathroom, which pumps to the shower in our en-suite. I now want to ‘T’ in to the pipework and fit a shower in the bathroom. Because of the confined space and existing layout of pipes in the airing cupboard, it would be a real help if I could T into the existing copper pipework using flexible plastic pipe and pushfit fittings.
    So what I’d like to know is can I use pushfit fittings and pipe in conjunction with the shower pump? (ie would the increased pressure be a problem?)
    Also, although I’ve got plenty of flexible plastic pipe, I thought I might make things slightly neater by using John Guest 15mmx15mm 300mm pushfit flexi hoses. Would they be suitable? And finally, would the fact that the bore of these hoses is only 10mm present a problem?
    Er, that’s it! Hope that made sense.
    Thanks in advance,
    Ade
  2. Sponsored Links
  3. Softus
    Softus
    21 Oct 2004
    19,558
    Thanks Received:
    12
    Country:
    Yes. The pressure will not be a problem, although I have no idea why you think there will be an "increase" in pressure.
    IMO they don't make the job any neater, but they do make for more maintenance because they have shorter life than plastic or copper pipe.
    Hm. I don't like them, personally.
    Yes - 10mm will be quite restrictive. You should follow the shower pump manufacturer's guidance and recommendations.
    One last thing - always the correct pipe support inserts for the brand of pushfit fitting that you're using.
  4. wouldbplummer
    wouldbplummer
    3 Jan 2006
    44
    Thanks Received:
    Norfolk
    Country:
    cant see any probs wit that idea just make sure you use proper pipe cutters when cutting copper pipe for the t dont want to f--- the rubber o-ring seal up
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
