pushfit on mixer taps
16 Mar 2009
Nottinghamshire
Hi to all
am fixing a new sink in utility next week, there is going to be a very limited space to work in so wondered if flexi, push fit fittings to the tap tails will be OK they are 15mm tails, also which pipes hot/cold or both do check valves need to go on :?:
cheers
try a couple of these :idea:
thanks Kev
are they compression or pushfit? I see they also have valves on the are they service valves or check valves, failing all else is it possible to do away with the tails and buy flex ones that would make life easier :?:
Cheers
