I accidently put central heating cleaning fluid in the wrong hole of the plate heat exchanger. Instead of putting it in the heating system side i put it in the other sides.
I then put it under hot water to clean out the liquid. Would you say it is safe to put back in the boiler. As the water will obviously then come to taps.
Or is it better to get a new heat exchanger.
