I've posted previously because I have two HW cylinders in my attic which are usually heated via the gas boiler. Occasionally I would use the electric immersion heaters to top up. Each heater is 3kW and at present they both plug into one double socket (I don't switch them on at the same time presently for this reason). When I posted previously I thought they were on the upstairs ring (not sure why) but having traced it back to the consumer unit they appear to be the only items on what appears to be a 2.5mm(2) T+E ring. It's an old Wylex CU with rewireable fuses. The problem is that the fuse at present is only 15A which would be inconvenient if I was using both at the same time. So my questions are:
1. If the fuse was large enough and I wired each heater off a seperate 13A FCU, and the cable is indeed 2.5mm(2) would this size cable be sufficient? I'd rather avoid changing the cable (e.g. for a 4mm(2) radial) as I'd have to put in a new run.
2. If it is sufficient how much spare capacity would there be on the ring?
3. How can I check for sure that the cable is indeed 2.5mm(2)
4. I assume I'd need a 30A fuse but how can I increase the size of the fuse in the CU? In other words, can I simply change the fusewire to 30A and label the fuse as such (I'm guessing not) or do I have to get a replacement, in which case is such a thing available?
Sorry for the longish post, thanks in advance for any help!
