M
mark_j_k
OK here's what's been done already:
Radiator upstairs never got hot (you could bleed every day and still nothing), changed it and was fine.
Radiator downstairs went cold at the bottom (one pipe red hot, one cold)
Changed radiator and still nothing.
Balanced radiators to get them all hot, done.
Problem sorted? No, now one radiator (downstairs) seems to have alot of air rushing/gurgling though it constantly.
Pump is set on the middle setting '2' and the system is an open vented with a back boiler (not sure on make)
Any ideas on what I should try next?
Is it possible that air in being sucked in through a leaking radiator valve?I've been told that the radiators are from the 70's (apart from the 2 that that have been changed)
Thanks in advance.
Mark.
Thanks in advance.
Mark.
