PVA applied to ceiling - how to fix!
15 May 2013
Hi All,
I want to paint the ceiling of my garage white, its currently bare plaster with a coat of diluted PVA on it.
What should I do to try to remove the PVA so the emulsion will stick, sand? wash with sugar soap?
Any solutions greatly appreciated!
cheers
warm water (with a sprayer) and a metal scraper would do it, the glue will turn to slime, and you wipe the slime off the blade of your scraper.
It can also be coated with an oil-based undercoat but I have not done that, someone else will comment.
You might try flogging whoever put glue on a surface that is to be painted.,
Give a bit of a sand then as suggested give a coat of oil based undercoat, emulsion straight onto undercoat.
