pyronix 46 comms 485 fault
26 Jun 2006
London
so the key pad on our pyronix 46 no longer seems to work properly
if i try and enter the code when i get to the fourth digit an error 485 comes up, after a bit it goes away
weirdly the fob still seems to arm the alarm
but i cannot get into the engineer menu either as same problem
i have done the long press on D and checked that the address is 00
bit worried if i take the case off to check the wiring and the tamper alarm goes off i won't be able to reset it if the keypad is not talking properly
any thoughts on what we can do?
Tricky one as could be anything on the data line. Are there any other keypads, tag readers, zems ? If just the one keypad you want to be checking for 1/4v between 0v and d3/d4. Check cable resistance. If all ok all you can really do is try a new keypad. If other devices on data line then disconnect one by one to see if fault clears
can i open the keypad box without triggering a tamper alarm or the like, can battery failure cause these symptoms?
don;t think there is anything else on the line, very simple home setup, just one keypad with integral tag reader and 3 pirs and the bell is all we have
odd how the tag seems to work but as soon as a fourth digit is typed in that goes to the main box it errors ( doesn not do this on the keypad config though so not an issue with the keys )
bit worried about setting off the alarm and not being able to shut it down, we got a lot of grief when our old one broke and got stuck on
going to be annoyed if the keypad or even worse the main box has failed after only 3 years
Could just be a loose wire lol u wont know til u open it. U can silence the tamper alarm with fob once activated....... hopefully not been left on engineer restore.......
