Pyronix 46 euro
31 Oct 2005
Havnt used our Pyronix 46 euro in a while .
We tested the night mode yes b today worked great. We tested the fobs exiting the house it Armed all alarms area A no problem.
However when we tried putting our 4 digit code in to exit property the area B lights up. Ive tried to select A , just incase we want to use just the code for setting on exit and not the fobs. The system was shutdown and power failed as a car came into our living room and the fire service turned the electricity off and the battery B-up ran out. The memory of the system must be ok as it remembers our 4 digit code.
So can anyone remind me how to use the keypad exiting the house and getting all alarms to arm (area A). B is lighting up at present when we try this.
Help appreciated.
Neilc
Put in your code then open the final
Exit door …does it change to A setting when you open the final exit door ….if so it’s set to intelligent set
hi , I put my 4 digit code in and hid from my hallway sensor then jumped in front of it to get the PIR to light up on exit. It came up on the euro LED saying Hall exit but didnt change to A. :(
As i say it still works in night mode (in my case yes plus B) so the downstairs in armed on a night time. Also if we use the Fob and exit house it arms zone A .
Just years ago we used to use the kepypad digit code then exit .
We can use the Fobs for now.
Weird.
No the door contact was removed a long time ago and the wiring removed . In the exit zone we have a PIR now . So I pressed A plus yes and the system armed as it should . ( Thanks for this we had forgotten) however when we walked in front of the PIR near the keypad when I put the 4 digit code it didn’t disarm it seemed to want more digits .
We deactivated it using the fob .
As I say it went a bit screwy when the power was turned back on but it works fine night time mode yes plus b and we’ve walk tested this .
Wonder if it’s wanting an engineers code when we arm it yes A and try and dis arm it .
