Pyronix Alarm
25 Oct 2020
Hi
I have a Pyronix Euro 46 V10 Alarm system with a wired keypad in the hall and the control panel box is in the garage.
Out of the blue today the keypad in the hall went off with an alarm noise and has a yellow blinking light showing on the far left hand side. As usual I input my 4 digit code followed by NO NO which I normally do after a powercut and this usually stops the alarm sound and the light goes off. This time although the alarm sound has stopped but the yellow light is still blinking..
The fault showing up on the hall keypad after inputting the 4 digit code is "Control Panel ATSF All Paths".
The alarm system is in a 7 years old new build...........the alarm is never actually armed.....and not maintained.
Someone suggested maybe a battery needs replacing but I am not very technical and have no idea what is causing the problem
Any advice on this would be much appreciated.
Thank you.
ATSF, all path sounds like the all the communicators aren't working.
after a power cut it wouldn't be uncommon for a router to have lost power unless it had a UPS which most don't. sounds like you have a few power cuts, do they last very long?
However if it is the battery making the coms modules play up, that I find interesting as looking at a possibility of the battery being removed on another manufacturers panel causing something similar, but in that case batter was removed and a bigger one put in and it was after the change of the battery. so waiting to see if that reappears.
